Newbie from NYC. Modifying my intake and exhaust in hopes of gaining 100+whp :D
M
Maximumrisk
Max, looking great.. well done. I'll have to look at my Aeroforce gauge. I can set a alert on most any input, but I don't think I can do any external triggering.
The company sells a relay kit which includes a small electronic device that taps into the warning light of the gauge, which you preset thru the annunciator, that triggers a relay (or a solenoid in my case)
So, for example, i set the warning light to come on when the gauge reads coolant temps above 186 degrees which at the same time triggers your relay
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I've got two analog inputs but no outputs. I have my annunciation set to monitor knock voltage. The Interceptor gauge I have is several years old.
M
Maximumrisk
back from the dead!!!
The truck has been running fine all this time (knock on wood), but time to do something about the transmission has come. I have on order a 518/46rh transmission being built by Martin Saine. It'll be built to hold about 800hp, it will have a billet input shaft and manual valve body. It will be about 3-4 weeks before I receive it. In the meanwhile, I started working on the shifter stand. I will be using a Kilduff shifter called "the ratchet *****", it is a 2 lever shifter, one is a detent the other a ratchet.
As some of you may remember the truck is 4x4 so the stand has to accommodate the 4x4 shifter.
More updates as I progress. Any questions let me know.
On to the pics
ps Sorry that Photobucket f'ed up the thread :-(
Redtruck-VA
Virginia
20170704_162111.jpg Max, have you figured out the cable routing? Unfortunately the higher the shifter, the higher the cable.
M
Maximumrisk
as of now the plan is to put a little notch at the top of the ashtray lid and route the cable through it.
charonblk07
Calgary, Ab
F1-A forged 349ci
With a 545 it's only a matter of time before you get fed up with it, lol. I like the innovative way you've done it to make it all fit. Will you be making a cover for the base? Also looks like you're gonna have to relocate your gauges, probably can't see anything with the shifter in the way now.
Redtruck-VA
Virginia
That should make a good smooth run. Smoother the better.
M
Maximumrisk
LOL! You've got that right!.
The stand will be powder coated black. the transfer case shifter will get a boot.
Redtruck-VA
Virginia
It takes the 5ft cable to reach properly. I had 3ft when I made the 46rh swap and it didn't fit.
