Danny02453
I just purchased a certified 2015 Ram 1500 Outdoorsman 4*4 5'7 box crew cab. It has a 5.7 V8 Hemi 8HP70 trans with a 3.92 rear axel ratio. The sticker says it has a class 4 receiver and rear extra heavy-duty shocks. The sticker inside the door says the occupants and cargo cannot exceed 1192 lb. I did some research online and figured it could tow 10,000 lbs. I called Ram customer service and gave them the last nine or last six of my VIN and they said it could tow 10150 lbs with a tongue weight of 10% of that.
Based on that I wanted to buy a travel trailer. It is the bullet 2190ex. It has a dry weight of 4410 pounds and a payload of 1890lbs. It has a GVWR of 6000 pounds. The specs says it has a hitch weight of 560 lb.
I figured I was well under my tow weight and would be good.
I was cleaning my truck today and notice just under the license plate on the black part of the bumper it reads "5000 lb gross trailer weight max 500 lb Max tongue weight. Bumper only. Vehicle capacity may vary; refer to owners manual" . The owner's manual refers me to a website that shows towing capacity for 2017 and 2018 Rams.
Can I tow this travel trailer safely as is? The truck sticker also says it has trailer sway control and the truck has a tow/haul button.
Any help would be appreciated.
