No brake or turn signal lights
Discussion in 'Exterior' started by Brad141987, Dec 28, 2016.
Sponsored By: BAK Factory Outlet
  1. Brad141987
    Brad141987 Junior Member
    Dec 28, 2016
    Ram Year:
    Engine:
    Hemi 5.7l
    Hi all, this is my first post in this forum. Got an 07 Ram 1500 hemi 5.7l
    I have no brake lights or rear turn signals.
    Tail lights do light up.
    Reverse lights work.
    And third brake light over cab works as well.
    I checked and replaced all fuses.
    Replaced all bulbs. No luck.
    Front turn signals work fine although I get the fast flash. When I turn on hazards though, the front turn signals are slow not fast.
    Replacing brake switch tonight. Then multi function switch on friday. Anything else to try? Is there a ground wire for the rear lights that could be out?
  2. ms8091
    ms8091 Senior Member
    118
    15
    Aug 25, 2013
    Ram Year:
    Engine:
    4.7L
    I'm not sure if in yours if the turn and brake are the same bulb but if so, there is a good chance it's the turn signal switch in the column. Happened to me on an older Ram (1981) and the old timer next door was a semi service tech. After I screwed with it for hours, he diagnosed it in less than 5 minutes.
  3. hemi_loredo03
    hemi_loredo03 Member
    96
    50
    Sep 27, 2016
    TEXAS
    Ram Year:
    Engine:
  4. 979dodge
    979dodge Junior Member
    36
    10
    Apr 24, 2012
    Ram Year:
    Engine:
    4.7
    If your truck has been lowered, you might have damaged inside of fender wells and cut into wires. Happened to me and messed up wires that run on the drivers side. Had no back lights at all. After replacing everything from bulbs, to switch under dash, I saw wires were exposed and I just used electrical tape to fix. Been good ever since.
Share This Page
