Oil Catch Can Dump photos
Discussion in 'Engine & Performance' started by R.L.K., Mar 21, 2016.
Sponsored By: Moe's Performance
  1. R.L.K.
    R.L.K. Supporting Member
    10,243
    6,118
    Dec 1, 2013
    Bristol , Tn.
    Ram Year:
    Engine:
    Nice
  2. Royals
    Royals Member
    75
    21
    Dec 14, 2015
    KCMO
    Ram Year:
    Engine:
    Kind of irks me how the RAM family gets no love from the EE site, but I plan on ordering one very soon in hopes it will help with my hemi tick. :help:
    Moparboss99 and scott68fl like this.
  3. R.L.K.
    10,243
    6,118
    Dec 1, 2013
    Bristol , Tn.
    Ram Year:
    Engine:
    An OCC likely won't help with your Hemi tick but it will keep gunky vented oil / condensation / carbons and unburnt fuel out of your intake .
    For the hemi tick you should do some reading here
    https://tapatalk.com/shareLink?url=...&share_tid=27664&share_fid=17770&share_type=t
    Synthetic Oil
    Hope this helps !
    Royals likes this.
  4. charonblk07
    charonblk07 Senior Member
    3,967
    1,826
    Mar 14, 2013
    Calgary, Ab
    Ram Year:
    2009
    Engine:
    F1-A forged 349ci
    High vacuum scenarios are where you will build the most fluid in a catch can in N/A engines. The PCV is closed at idle but off-idle and low RPM driving where you are generating high intake manifold vacuum but not enough to keep the PCV closed is where it will develop the most build up. Cold engines with poor ring seal and high condensation levels will also increase the rate of build up. High RPM driving will also generate a lot of fluid through windage and blow-by however vacuum is lower, this is less of an issue on N/A engines but becomes a much larger issue with boosted engines.
    R.L.K. likes this.
  5. R.L.K.
    10,243
    6,118
    Dec 1, 2013
    Bristol , Tn.
    Ram Year:
    Engine:
    @ charonblk07 thanks for the explication Sir , that does make sense .
  6. JaredRAM2015
    JaredRAM2015 Senior Member
    32
    142
    56
    Dec 25, 2015
    Kilgore, TX
    Ram Year:
    Engine:
    HEMI 5.7
    3k miles with the CC, had it since I had around 200 miles.
    This may be around 3 dumps total?
    [​IMG]
    R.L.K. likes this.
  7. R.L.K.
    10,243
    6,118
    Dec 1, 2013
    Bristol , Tn.
    Ram Year:
    Engine:
    Ha , I'm collecting mine in a bottle also , I think I may send it out to Blackstone labs for an analysis, just to see the fuel and water contamination levels ...
    Hemi395 likes this.
  8. JaredRAM2015
    32
    142
    56
    Dec 25, 2015
    Kilgore, TX
    Ram Year:
    Engine:
    HEMI 5.7
    Yeah... I just wanted to track it for a bit, I try to empty it regularly while performing a few preventative checks.
    R.L.K. likes this.
  9. CMil527
    CMil527 Senior Member
    44
    3,041
    503
    Dec 8, 2014
    Old Bridge, NJ
    Ram Year:
    2015 Ram Express 1500 CC 4x4 - Black Edition
    Engine:
    wow... seems its doing its job!
  10. jlpowell84
    jlpowell84 Senior Member
    33
    527
    129
    Feb 17, 2016
    Ram Year:
    Engine:
    Why the hell did Chrysler design the motor to have these harmful vapors back into the engine?
    And if this is what happens does not everyone have one of these?
    I bought a 2012 with 65k miles as second owner. Truck is ridiculously clean and well maintained but did have some dried lack dust on inside of TB when I installed K&N CAI. I hope its not too late...Here I come again Moe's :/ My wife is gonna kill me :)
Share This Page
