Sticker says 3000 miles. I think dealers put 3,000 miles so you come back often and spend the money. If RAM says 8,000 miles I'm pretty sure I should be fine if I stick to it. I don't tow often. Maybe every few months. And 95% I drive in the city.is that a 3,000 mile sticker? The oil change interval is 8,000 miles max, the computer may tell you to change it earlier. I did my first at 5,000 (which was early) and I am going to do my second at ~ 12,000 miles (also early per the computer) but I don't think I would go as short as 3,000 miles.
And who it going to pay for the engine failure if it doesn`t hold up to 20,000? Surely not the oil company.I go buy the oil life meter also, today's oils are way better and can easily go beyond the old 2000 - 3000 mile rule. Heck, I've seen them advertise one oil that suppose to last up to 20,000 miles!!!!
It seems to me you knew what you were going to do before you even asked the question.Sticker says 3000 miles. I think dealers put 3,000 miles so you come back often and spend the money. If RAM says 8,000 miles I'm pretty sure I should be fine if I stick to it. I don't tow often. Maybe every few months. And 95% I drive in the city.
How much are you really saving by extending a oil change? Is it really worth a cam and lifter failure. Not in my book. Some will spend more on a darn fancy coffee then spend it on a early oil change.
Don't forget your to do your differential and transfer case fluids every 3,000 miles also.
Nope. As long as you follow what your manual says, which is, go by the monitor, unless 10,000 miles or 12 months comes first.Thanks guys for all the replies. I asked the question cause I wasn't sure if I'm doing the right thing by doing my oil change according to oil life monitor. I'm pretty sure RAM engineers knew what they were doing by putting this in the trucks. Another question is can the dealer decline any warranty work if I won't do it every 3,000 miles as recommended?
