Oil pan gasket on 5.7
Discussion in 'Engine & Performance' started by Jersey ram, Jan 11, 2017.
Sponsored By: Moe's Performance
  1. Jersey ram
    Jersey ram Junior Member
    18
    Oct 6, 2013
    Ram Year:
    Engine:
    Hey guys. I've got a 2004 5.7l 4wd, and I've got what I believe to be an oil leak coming from the oil pan gasket. Oil pan is in good shape. My question is, is it possible to replace the oil pan gasket without fully removing the pan? As I see that the latter option involves lifting the engine or dropping the pumpkin...
  2. Core-Lokt
    Core-Lokt Senior Member
    382
    79
    Jan 13, 2013
    Ram Year:
    2005 Ram 2500 4X4 ST
    Engine:
    5.7L
    I replaced my timing chain assembly and oil pump in November, so it's pretty fresh in my mind. That said, my truck is a 3/4-ton and if yours is a 1/2-ton, not everything is possibly applicable.
    There isn't so much a gasket as there is a windage tray with molded gasket. The oil pick-up tube runs through the windage tray and is fastened to an extended #3 main bearing cap stud on the bottom (sump side) of the tray.
    The trick is to get the new windage tray between the pan and block and slip the pickup tube bell through that windage tray opening and get that #3 stud fastener attached. But I did it alone and on my back, so it can be done at home. Either allow ample time or get a helper; just having one end of the pan supported while you shuffle things around would help.
    I read that the corners of the pan where (at least) the timing cover attach to the pan/windage tray are supposed to have a sealer bead. I got a Fel-Pro windage tray and it came with a small tube of black Permatex. IDK if that's included with all trays or if a subsequent spec revision doesn't call for it. I did make a small bead all the way around the top of the tray. Good luck.
    Jersey ram and RonJon '06 like this.
  3. RonJon '06
    RonJon '06 Senior Member
    3,304
    1,047
    Jan 2, 2014
    Southern Minnesota
    Ram Year:
    2006, 1985
    Engine:
    5.7, 360
    My '06 4wd has a 2500 frame as well. It's extremely tight but like Core-Lokt I was able to unbolt the pickup tube and remove the oil pan without lifting the engine or removing anything from the underside of the truck.
  4. Jersey ram
    18
    Oct 6, 2013
    Ram Year:
    Engine:
    Thanks for this info, I wish I had seen it earlier today when I was working on the truck. I guess I need to turn on notifications
Share This Page
