OP sending unit question
Viper21700
Woodbridge VA
98 CTD 12 Valve- Half the valves, twice the fun
Ok 12 valve guys, Im replacing the oil sending unit next week, and my local dealership has the unit for 54$. its a two pin sending unit. My question is, is the original a 2 pin, 1 pin, or what? Is this the unit that requires the re-flash and rewire?
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Stock should be a 2 pin.
Shouldn't require a flash just for a oil pressure sender. You might consider go to Cummins dealer instead for a sender it might be a bit cheaper.
