Other Fusible Link
Discussion in 'General Discussions' started by ewbloom, Feb 5, 2017.
  1. ewbloom
    ewbloom Junior Member
    22
    Aug 30, 2013
    Sourthern Illinois
    Ram Year:
    1988 D100
    Engine:
    3.9L V6
    I trying to find the pick and orange wire fusible link for my blower, I found a bad patch with a broken wire.
    The battery side has five wires coming out of one black wire. Four of the wires are 12ga (I think) with one being much heavier. The broken wire had a bad patch link the feed to a pair of wires (one black, one pink) both 12ga or maybe 10ga.
    Both ends with multiple wires are clearly molded pieces and meant to merge the wires.
    So what might this fusible link be? And what size do I need to get to replace it?
    I have enough wire coming from the 5 wire end to make a connection. The other end where the black and pink are connected will need to be cut becuase the break was right at the molded rubber / plastic.
  2. ewbloom
    22
    Aug 30, 2013
    Sourthern Illinois
    Ram Year:
    1988 D100
    Engine:
    3.9L V6
    I just found out that this is the heater fan fusible link I have been looking for.
  3. Sniper X
    Sniper X Senior Member
    50
    113
    10
    Dec 7, 2016
    Ram Year:
    1991
    Engine:
    318
    That's always the first one to burn up
    I don't trust those, swap mine to fuses.
Share This Page
