YerpDerp_1
I have a 1997 with a 5.9 magnum engine and when i drove to work the truck was fine. I let one of my delivery drivers borrow my truck because her car was sputtering on her. It was fine when i gave the truck to her and when i got it back i noticed the engine was getting hotter than normal. It was also 93 degrees for the first time since I've owned the truck. When i turn the heat on all the way to circulate the truck the temp returns to 200 degrees but as soon as i accelerate to quickly or turn off the heat, it shoots up to around 235 to 250 degrees. Both heat and AC work great on this truck. I'm thinking water pump, thermometer, or maybe radiator flush but before i do anything i was hoping for a second opinion. I bought the truck in the dead of winter, and the worst I've had to replace so far are U-Joints. This is the first serious problem with the truck since I bought it. I've kept up on all my oil changes with Max Life 5w30 Synthetic blend. I have not done any fluid flushes at all. I'm also missing the coolant overflow cap. The owner sold it to me with gorilla tape over where the cap should be. It hasn't been a problem so far, but maybe that's affecting it?
Lastly, i forgot to add, its at 163,033 miles. Maybe its just showing it's age?
