P0216 & p1693...
Bird2173
Macon, GA
Cummins 5.9
P0216 is the dreaded vp44 code of death correct? :flipthebird:
From what I can find, I have two definitions of the 1693: Tachometer Circuit Low voltage and DTC detected in companion JTEC Mod. Any help deciphering those 2 definitions?
B
Bird2173
Macon, GA
Cummins 5.9
the bird is for the code... not to the viewers!
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
P0216 code is a wear issue of the timing piston. Kind of like this... This one was nearly seized tight in the bore.
