Alan Summers
- Feb 17, 2018
- 18
- 10
- Location
- Metro Atlanta, GA
- 2010
- 5.7L Hemi
Hi, newbie here. 2010 ram 1500 5.7L Hemi pulled a P0303 code indicating cylinder 3 misfire. I found one related thread (http://www.ramforum.com/threads/p0308.92794/) but it showed no conclusion.
I have completed the following, in order:
1. Added some additives (seafoam, z-max) in an attempt to clean out any build up in the injectors or combustion chamber. Checked all connectors at coils, injectors and PCM.
2. Unplugged the PCM to clear the code, which it does, and the code returns after 15-30 minutes of driving.
3. Checked the plugs on #3 and they are very worn. Put the plugs back in (for now), swapped the #3 coil pack with #1 coil pack and cleared the code. Code returns, still on #3 so eliminates (I hope) the coil pack.
3. Pulled one of each pair of plugs and checked compression. Average is 210 (did not have the throttle body open) with a low of 200 and high of 215. Cylinder #3 is right at 205 where it should be...
4. At this point I have all plugs removed and new plugs (NGK LZFR5C11) ready to go back in but I want to swap or replace the fuel injector on #3.
Any suggestions? I looked for a DIY link on fuel injector replacement and cannot find one here, again a newbie. First question is can I put the plugs and coil packs back in and then do the fuel rail/fuel injector removal? To anyone with links to directions or videos, I thank you in advance!
