P0507 code
cubmedic
Danville, Va
I have a code P0507 pop up last night. Any ideas how to fix this? It is for high idle.
Thanks
BC
Jstmahoney
Northern California
2017 Ram 1500 5.7 Crew Cab 4x4
Few ideas to check, how many miles do you have?
Intake air leak
Faulty or clogged IAC valve
Carbon buildup on the throttle body
Faulty power steering pressure switch
Alternator that has failed
ColdCase
Also PCV valve or system leaks, wire harness or connectors. PCM
cubmedic
cubmedic
Danville, Va
Got it fixed was the catch can hose from catch can to the throttle body.
1Popeye
