LegndLarry33
I know there are a lot of post about this, but I think I've read most of them and am still trying to clarify a few things if there's anyone out there that can help....
2007, 5.7L with MDS, 154k mi... new to me though, I've only had it for about a month...
Was sitting in a drivethru line a few days ago and the light came on... oil pressure never really wavered as far as I can tell.... tried to attach a picture of gauge to show where it usually sits at a warm idle and where it was when the light came on, but couldn't figure out how to do that in the post... the needle is basically just left of the center (12 o'clock) mark.
Read stories of people saying the gauge will drop to zero and bounce back, but I haven't seen that. I've taken 4-5 trips since then and haven't seen the gauge do anything abnormal. Changed the oil yesterday with Mobil 1 High Millage (5W-20), and a MOPAR filter. Based on the sticker that was on the windshield from the previous owner, it looks like it had 5W-30 in it. Light is still on today though.
Questions....
1) I believe there is only 1 sensor, so the same signal that is going to the engine control to set the light is whats driving the gauge, correct? If so, then obviously some level inside of the "acceptable" gauge range is going to trigger the light?
2) The fact that I've never seen anything crazy out of the sensor would lead me to believe that the sensor is fine...?
3) Seems like I might working my way toward a software update (via tsb #1804407)? Which presumably is their (Dodge) way of saying "everything is fine, but we set the range on the signal too tight"?
Appreciate the help
Questions....
Appreciate the help
