Passenger bulb out
Andrew09HEMI
So this is a recent issue although it could go back to when I first installed. My passenger bulb has always been dimmer than the driver and this evening it went out. If I turn the truck off then back on again it'll light up very dim then go out. I haven't taken the assembly out yet to determine if its wiring issue but hoping you could shed some light. Thanks!!!
bhonshell37
Washington
My friend with an 01 Ram had a similar problem. Bulbs burning out and dim. We discovered a wire in the harness lost the coating and was shorting from moisture. He thoroughly covered the wire with electrical tape and no issues since
Sent from my SM-N910V using Tapatalk
Andrew09HEMI
Andrew09HEMI
I'll take a look tmrw but this is kinda why I hate aftermarket stuff. Not saying I don't like the look and brightness but having to worry about it going out and not being able to just swap a bulb at a store is not fun
dzltek
Sounds like high resistance in the wiring, not allowing proper voltage to to the bulb. Definitely check your wiring, if it is all good and corrosion free, check your plug, they will burn and melt, not allowing good contact. Also ohm out your bulb. It could be bad also
