Pcm bad?
Discussion in 'General Discussion' started by i_burn_diesel, Feb 7, 2014.
  1. i_burn_diesel
    i_burn_diesel Junior Member
    21
    8
    Feb 3, 2014
    Southern. IN
    Ram Year:
    1998
    Engine:
    12v 5.9
    Hey guys I'm new to this forum, just recently traded my 2003 Chevy Silverado 2500HD 6.0 for a 1998 12v Dodge 5.9 Cummins Dually. I had problems in my Chevrolet (go figure) with the instrument panel going bad instrument motors not working. When I picked up this new truck I noticed none of the instrument panel worked at all, either. Speedometer, tachometer, fuel gauge, oil gauge, ect don't move at all. All of these warning lights are lit up on the dash, though. The alternator is fine but will not charge the batteries and I have tested the alternator to make sure it is fine and it is. So I set up an external regulator to charge the batteries and I've been looking around some forums and such but cannot get a definitive answer on whether it is the PCM or not. Thanks for any input on the matter.
    -Logan
    -Logan P
    1998 5.9 12v long bed cummins
    "farm truck"
    Been shootin sh** since '96
    i'm a Copenhagen cowboy
    Born n' raised Southern IN
  2. i_burn_diesel
    21
    8
    Feb 3, 2014
    Southern. IN
    Ram Year:
    1998
    Engine:
    12v 5.9
    Any ideas
    -Logan P
    1998 5.9 Dodge Ram 3500
    "farm truck"
  3. rustydagger
    rustydagger Senior Member
    430
    44
    Dec 9, 2013
    Near McAlester, Oklahoma
    Ram Year:
    Engine:
    hemi 5.7 with K&N CAI and Diablosport Trinity Tuner
    From what I understand on those trucks the voltage regulator is part of the pcm and in 90+% of cases if the alternator and batteries are for sure good it is the pcm.
    Unless some wires are melted or chewed somewhere.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  4. rustydagger
    430
    44
    Dec 9, 2013
    Ram Year:
    Engine:
    Have you taken it anywhere and had them read the obd codes?
    Is the wiring tampered with much? There are several systems that people can and do bypass instead of replacing parts.
  5. Redtruck-VA
    Redtruck-VA Senior Member
    5,371
    692
    Virginia
    Ram Year:
    2003 & 1989 D250 RWD
    Engine:
  6. Merc225hp
    Merc225hp Senior Member
    5,141
    3,118
    Jan 13, 2013
    NA
    Ram Year:
    truck
    Engine:
    gas
    Not my best area for these trucks but there is a fuse for all of that, no bus should be a code and I think the fuse is called oid or ord or oid ???? I will see if I can find it and post back.
  7. i_burn_diesel
    21
    8
    Feb 3, 2014
    Southern. IN
    Ram Year:
    1998
    Engine:
    12v 5.9
    Redtruck-VA I already have an external regulator installed and the batteries charge.
    -Logan P
    "farm truck"
  8. i_burn_diesel
    21
    8
    Feb 3, 2014
    Southern. IN
    Ram Year:
    1998
    Engine:
    12v 5.9
    I don't believe the wiring has been tampered with he told me he took it to dodge dealership and they said it was the pcm but I just wanted to double check before I shell out $400 to get a new pcm and it flashed
    -Logan P
    "farm truck"
  9. i_burn_diesel
    21
    8
    Feb 3, 2014
    Southern. IN
    Ram Year:
    1998
    Engine:
    12v 5.9
    Okay merc get back at me, I appreciate all the replies guys. Thanks for all the input loving the new #dodge pickup
    -Logan P
    "farm truck"
  10. rustydagger
    430
    44
    Dec 9, 2013
    Ram Year:
    Engine:
    What are your plans for this truck? It would be a good time to switch to a performance computer system or something like that lol
Share This Page
