PCV Location
cmm47172
2008 Dodge Ram 1500 ST Regular Cab
3.7 L V6
Can someone give me a part number for the PCV and tell me where it is located? This is on my 2008 Dodge RAM 1500 ST, 3.7L V6.
Thanks!
MarshRam
2014 SLT 4x4, 2012 ST
Thanks!
If it is anything like my 07 4.7 liter then it is at the back corner of the engine on the driver side. If you know what the pcv looks like, get a flashlight, lay on your engine, tweak your neck so you can see down there with your right eyeball, you'll see it. Changing it is even more fun!
cmm47172
cmm47172
3.7 L V6
Thanks. Is it a half steel half plastic screw in part? What does the hose connect to at the other side of the engine?
14RAM1500BG
maryland
Without actually seeing the hose I would say it is the source of vacuum.
fastf
Georgia
2005 Ram 1500 Quad Cab SLT Thunder road
Marshram the pvc is on the passenger side of the truck on a 4.7 on the side where you add oil .
