Pedal Commander
RAMHON
NJ
2021 1500 Laramie Crew Cab 5 4X4
5.7L V8 HEMI® MDS VVT Engine
Anyone using this (claims 20% MPG fuel savings):
https://www.amazon.com/dp/B00O832XVE/ref=sspa_dk_detail_3?psc=1&pd_rd_i=B00O832XVE&pd_rd_wg=NZ6rv&pd_rd_r=KZEF14VW191SGNPRA0TR&pd_rd_w=0jg9F&smid=A1KGI2XQGXJY7F
Pedal Commander throttle response controller PC31 for Dodge RAM, Charger, Magnum, Challenger, Dakota & Durango - get increased performance or save fuel up to 20%
Easy plug & play installation, NO mechanical experience required!
Pedal Commander can be installed in 10 minutes or less. It is a complete plug-&-play system that connects above your gas pedal and stays inside your car, you don’t even need to pop your hood. If you can plug in a lamp, you can install Pedal Commander.
We have tons of example install videos on YouTube to help you get a general idea of just how easy it is to set up!
Pedal Commander is compatible with the following Dodge models and years:
Challenger (2008 and newer)
Charger (2007 and newer)
Dakota (2007-2011)
Durango (2011 and newer)
Grand Caravan (2008 and newer)
Magnum (2007-2008)
Nitro (2007-2012)
RAM (2007 and newer)
What is Pedal Commander?
Pedal Commander is a throttle response controller that removes response delays on any vehicle with an electronic gas pedal (most vehicles made after 2005). This is achieved by amplifying the signal being sent from the sensor on your gas pedal to the vehicle's ECU (computer). Today’s newer vehicles lack the responsiveness that came with older throttle cables. It doesn’t matter how fast you push your gas pedal to the floor, you don’t have access to all the power your vehicle has to offer. We are your solution!
One of our most frequently asked questions is “how much horsepower does it add?” Pedal Commander doesn’t add any horsepower, but it does let you use the existing horsepower of your engine by allowing you to access it quicker with the amplified signal.
This performance increase cannot be achieved with your typical aftermarket tune or programmer. Pedal Commander is the only device that lets YOU choose how you want your throttle to respond and change it on the fly. There are 4 different modes, with 9 sensitivity levels for each mode. This gives you a total of 36 levels of response to choose from, ensuring there is something for every driver in every vehicle.
While there may not be anything else out there like it, Pedal Commander is completely compatible with any other aftermarket parts you may already have. And since we don’t use the OBDII port, this means it’s a perfect match to compliment your existing tune or programmer to maximize your driving experience.
Undetectable by dealerships, won't void a maintenance plan!
We understand not wanting to risk voiding the maintenance program on a new vehicle, but that no longer means you have to wait 5 years/50,000 miles before you can start customizing your car or truck to drive how you want it to.
When a dealership does any kind of work or repair, they run a scan on the vehicle's computer to see if anything has been changed. Other aftermarket tuners and programmers will leave "flags" on the ECU after they've been installed, and will remain even after they've been removed. These digital footprints are what cause the dealership to void any kind of claim or maintenance program.
Pedal Commander is 100% UNTRACEABLE by dealerships. Before going in for service, just make sure you turn the unit off and tuck it out of sight and you're good to go! You can leave it plugged in, no need to un-install or re-install, and they'll never know it was there.
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Nope. Nobody here uses this. J/k there is a thread here titled "the pedal commander review" that has hundreds of posts. I have one and haven't realized the 20% gain in mpg but it is fun. I also don't run it in eco mode though.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I don't care about the gas mileage so much, but LOVE the performance it added to mine. Worth it for sure.
Dbush36
Fort Wayne IN
Pretty much everybody on this forum would like to see the 20% reduction in fuel usage and it may even be capable of it! But it is so fun to drive with I and probably everyone else can’t seem to any length of time in eco before We switch back to “FUN mode”. Lol
bchap05
I had the fiance order mine on the black friday sale but I can't play with it until christmas :( Sitting in my house waiting for me
JSVT3
PA
Take it and install it, and put rocks in the box and rewrap it :D
I second this idea. Orrrrr print a picture of it, tape it to some folded up cardboard, slap an old USB cable on it and you're done. She won't know the difference when you open it. :naughty:
Nick@GotExhaust
Preferred Vendor
SC
I have one on my truck and when I am not hot rodding around I got about 1/2 mpg increase. The better throttle response makes it worth it alone!
We are running 20% off them. PM if you would like a quote and to order or you can use promo code NPPCXMAS on our site!
Sent from my XT1650 using Tapatalk
Wahrsuul
Central S.C.
Still playing with mine, haven't found the "permanent" setting yet. Haven't really tried the ECO mode though, might have to give that a try. Sport+ mode on the other hand is almost uncontrollable for me.
JSVT3
PA
I can't wait to get mine. I already told Nick I don't really plan on trying Eco mode, haha. I want to roast some tires. :)
Rampaige
I’ve had mine for about 3 months now and absolutely love it!
Unless the roads are wet or I plan on going “off road” I usually leave it in Sport+........but I had to teach my self to “feather” the go pedal lol. I’ve never tried the eco mode & I don’t plane on it, I didn’t buy it for that mode lol
Pa.hemi.ram
Pittsburgh
Hemi 5.7, 6" Rough Co lift, Fuel wheels, Bully Dog Gt, K&N CAI, Magnaflow Exhaust
Does your PC make clicking noise when you put your truck in gear??
goose2232
After reading the other reviews on the pedal commander I took the plunge and purchased today. The throttle response delay has bothered me from day one so I am looking forward to getting it installed ASAP! Will leave review when I get it hooked up...
Sent from my MHA-L29 using Tapatalk
Nick@GotExhaust
Preferred Vendor
SC
You guys are going to love it. Most of you that ordered today should already have your tracking info!
You guys are going to love it. Just be careful in the rain. Holy crap I got sideways today pulling out of a side street quickly in my Power Wagon lol I had it turned up still from playing earlier on. quickly turned it back down to my "normal" setting
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
I definitely didnt install mine for any mileage increase but for the WOW increase. I run mine on sport 4 setting usually and every once in a while find myself screaming off the line from a stoplight... whoops, need to feather the petal...cool- no cops
Lmao
R
RAMHON
NJ
Thanks Nick - I concur it's downright scary fast in Sport + mode. Mine arrived today direct from CA/Vitalin Auto Performance. Slick packaging and took 10 seconds to install. Mine had a green warranty sticker on the controller - must have been a warranty/refurbished unit but I'm ok with that given discounted price. Seems to work normal and very intuitive controls. I really wanted it for fuel saving/range expansion but will be fun to test off the line.
Pa.hemi.ram
Pittsburgh
Does your guys pc make a “clicking” noise when you put it in gear??
