BlackMagnum2000
- Jan 9, 2014
- 6,145
- 2,340
- Location
- Locust Grove, GA
- 2000
- 5.9 Magnum
Alright so I finally narrowed down my noise (whining/howling at 15+mph in any conditions) to the rear end. Pulled the cover to find a TON of metal.
Start tearing it apart.
Pattern is fine. Gears are fine. Races fine. Bearing rollers are fine.
I finally found a spot on the outer pinion bearing where there was a small groove. On the pinion flange, there are small grooves and a lip on the inner edge. Do you guys think this is my problem? And also, what would cause this? I understand the damaged flange could damage the bearing, but how would those grooves develop on the flange in the first place?
