Puddle light replacement
BAMAMAC
HEMI 5.7
Lights have quit working on passenger mirror, they are manual fold . Can these be fixed without changing whole thing out ? Also have key fob problem, when key is removed from switch the lights start flashing on and off , have changed battery 2 times and lights still flash.
chris52010trx4
ontario
if your trucks still what it shows in your info as a 2011 then yes... i paid like 50bucks canadian... and you just pop it out with a small flat head...check the 2 wire leads for corrosion and then unplug put new one in and pop it back into place.. i siliconed mine after to seal it abit better... also had to replace the connectors on the wires due to it litterally corroding off ... as for key fob.. not too sure
