Purple Cranium covers
Corvette427
PA
Anyone put one of these on the rear diff only? Is it just the cage or does an entire cover and cage come with it?
Thanks!
Low_Sky
6.4L
It’s just the rock guard and bolts. Diff cover not included.
Corvette427
Corvette427
PA
10.5 or 11.5 rear end in these trucks ( mines a 2018)?
Corvette427
Corvette427
PA
Thank you. OK last question, when installing this guard, when you remove the bolts in the differential does the gaskets still hold the fluids in to give you enough time to put in the new bolts with the guard?
Basically does the whole differential drain out and do I have to refill it?
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
when i did mine, the front was bone dry after the install, and the rear had maybe a few drops on the bottom of the diff.
Corvette427
Corvette427
PA
Cool, thank you friend!!!
LakeFisher
Missouri
2018 Power Wagon
Yep, I agree with IRSmart. I left the bottom bolt last and just a drop or two came out before I had it on and a few bolts in.
Corvette427
Corvette427
PA
Well thank goodness I have a white PW, I hear the seals are better than the red PW! Should be no drips!
read it on the internet, has to be true.
GottaBeKD
CA
Might be a good excuse to change the fluids if it's worth doing.
Sent from my SM-G955W using Tapatalk
Sdreeser
Maryland
6.4 hemi
What's the party number for front? I looked on their website and they are only showing rear for the 2500
IRSmart
Westminster, MD
2018 Power Wagon
6.4L Hemi
MJockey
TENNESSE
Hemi 6.4L
What color cranium do you plan on getting?
Sdreeser
Maryland
6.4 hemi
Cool, that will look nice with white truck. I'm also going with skull instead of spider
IRSmart
Westminster, MD
2018 Power Wagon
6.4L Hemi
I went with the skull for the rear. I called and asked them if they could match and do a skull for the front, I was told no, that there wasn’t enough material for the skull to attach to and that I “would understand once I got it.” Well, I got it, and I don’t understand why they couldn’t do it.
