puzzled
crazzywolfie
under the truck
i would also say you got a loose belt. since i also got a 81 i can tell you tightening the belt is a real pain in the @$s. you can loosen the bolts and you will NEED a 1/2" drive ratchet or breaker bar to rotate the pump/bracket and tighten the belt.
