PW 6.4 tuning avaliable?
JJP71584
Pgh, PA
I currently have a '12 1500 with the 5.7 with HF tunes...I'm playing with the idea of getting a' 17 PW with the 6.4. I was wondering if tuning is available for the newer 6.4's to make it quick?
Sent from my SM-G935P using Tapatalk
MADDOG
Not RamForum Staff
Yes, there is programming available.
You'll need a programmer (Diablosport I3), an unlocked PCM (your OEM one is encrypted) and I'd highly recommend a custom tune.
You can get a package from Matt at Moe's Performance or from Sean at Hemifever Tuning. You can use your OEM PCM as a trade in on the unlocked PCM or keep it to swap back into service for those visits to the dealer.
JJP71584
JJP71584
Pgh, PA
Ok, great. Thanks for the reply. I bought my diablo tuner from Moe's with the HF tuning and have been very happy with it... I'm glad to know that the 6.4's can be tuned, makes me want a PW even more!
McBroom
Denison Tx
Hemi 6.4L
What kinda $$$ would that be?
I Love My 2018 RAM 2500HD 4x4 6.4L
Mod list: Pedal Commander, AVS Vent shades, Solo Delete kit, molar side step rails
JJP71584
JJP71584
Pgh, PA
Looking at Moe's website, it appears to be about $900.
G. Mcpherson
Yacolt, Wa.
2023 Ram 2500 CC SB Tradesman
Just a thought that you might want to purchase a PCM and keep yours for when you go in for service.
JJP71584
JJP71584
Pgh, PA
Would an unlocked PCM cause warranty issues?
Sent from my SM-P600 using Tapatalk
MADDOG
Not RamForum Staff
In a word, yes. And since the PCM is the powertrain control module, the dealer could deny any powertrain component warranty.
It's not right to do so but to get anywhere you'd have to fight it under the Magnuson - Moss Warranty Act.
Which is why it was recommended to keep your OEM PCM and use it as needed.
JJP71584
JJP71584
Pgh, PA
Thanks for the clarification, I appreciate it. Guess I'll be planning on keeping the stock PCM if I make the jump.
jambbii
Mesa, Az
Has anyone actually put their truck on a dyno? Just wondering what real numbers are.
Derek Powers
I'm willing to bet that even with putting the stock PCM back on before taking it to a dealer, if they dig deep enough they will figure out you switched them at some point.
JJP71584
JJP71584
Pgh, PA
Perhaps someone who works at a dealership could confirm that
Low_Sky
6.4L
The truck stores a code if you pull the ABS fuse and put it back. I think it’s a safe bet that it stores a code if the PCM gets swapped.
JJP71584
JJP71584
Pgh, PA
Is the code stored on the PCM or elsewhere?
22hemi13
Tucson AZ
2014 2500 4x4
Ha half the dealers can’t change oil or do simple service correct. Doubt they’d spend too much time for a repair just to see if pcm was swapped.
VLG6963
