Question about rear window?
Discussion in 'Exterior' started by CoreyLRam96, Nov 23, 2016.
Sponsored By: BAK Factory Outlet
  1. CoreyLRam96
    CoreyLRam96 Member
    78
    May 13, 2015
    Ram Year:
    1996
    Engine:
    5.9
    I have a sliding rear window and was wondering how easy it would be to replace it with a solid window instead. Could someone link me to a video?
  2. Meatball12
    Meatball12 Member
    78
    15
    Sep 23, 2015
    Carroll County, MD
    Ram Year:
    1999
    Engine:
    5.9 magnum
    Its harder than you think. I have a solid rear window and wanted to go to a sliding. So I've done my research. The rear window is nearly impossible to remove at home. Its set in with a rigid foam/ epoxy stuff. your best bet is to get it professionally done. and it will be cheaper in the long run if you mess it up which is a Very likely outcome.
  3. CoreyLRam96
    CoreyLRam96 Member
    78
    May 13, 2015
    Ram Year:
    1996
    Engine:
    5.9
    How much is it to have a professional do it though? They charge out the ass for labor
Share This Page
