Question on clay
Discussion in 'Detailing' started by EWC88, Feb 19, 2014.
  1. EWC88
    EWC88 Senior Member
    1,342
    205
    Apr 2, 2013
    Southern NJ
    Ram Year:
    2002
    Engine:
    4.7
    Come spring I really want to detail my truck. With that I want to clay but have three questions on clay.
    1- I see there are different grades of clay, I have never clause this truck the 3 years I have owned it. What grade would I get?
    2- I see there is clay and also clay mitts, recommend either or for first timer?
    3- I have pin stripe on my truck, nonpainted kind, do I not go over that with clay?
  2. parttimer
    parttimer Member
    99
    11
    Jan 7, 2014
    Ram Year:
    Engine:
    A standard clay should do you fine, mothers, megs who ever. After you clay you will usually need to polish. The clay mitt you see is probably a nanoskin type product. I use a nano skin towel for my work, I also have a disk that goes on my DA polisher to use as a substitute as well. The other products are more expensive, however in my use they are WAY WAY I can't say it enough, WAY faster. I can do most any car/truck with the towel in about 20-30 minutes. In that time you might clay your hood with a clay bar.
    You should be fine with the pin stripe, I have used my towel over them with no issue. Just get close with the clay if you're worried.
  3. EWC88
    EWC88 Senior Member
    1,342
    205
    Apr 2, 2013
    Southern NJ
    Ram Year:
    2002
    Engine:
    4.7
    Yea the two types of clay mitts I've seen are offered from autogeek and chemical guys. What products are you referring to are way faster?
  4. Graygoose
    Graygoose Diplorable
    7,007
    1,468
    Nov 21, 2011
    Oklahoma
    Ram Year:
    2015 Silver CC
    Engine:
    I used the Mothesr Clay Bar kit, worked out awesome, and really easy!
  5. kkreit01
    kkreit01 Senior Member
    857
    115
    Nov 12, 2012
    Olathe, KS
    Ram Year:
    Engine:
    I've tried 3 different OTC clays, and Mothers was the worst by far. I preferred Griots or Blue Magic way over Mothers. Mothers was real picky with lube. Since it's your first time, just buy an OTC kit. I wouldn't go crazy harsh. You could do more harm than good.
  6. FancyStancy
    FancyStancy Senior Member
    361
    86
    Mar 19, 2013
    Ram Year:
    2008
    Engine:
    Cummins 6.7
    Make sure you use a good lubricant! Be very liberal with the spray wax or whatever method you're using. One other tip that might be useful is to keep some hot water in a cup close by. You want to re-shape the clay about every panel (depending on how much gunk you picking up). Dropping the clay in some warm water makes the clay much easier to kneed and it helps keep it lubricated. Sorry if you know this, but if you didn't this should help! If you want a good quality clay bar, that will last you for many clay sessions, Adams Polishes makes a great clay bar http://www.adamspolishes.com/p-1004-new-adams-made-in-the-usa-detailing-clay-bar.aspx
    ..and for your lubricant, use Adams Detail Spray
    http://www.adamspolishes.com/p-870-adams-detail-spray-new-formula.aspx
    This might be a little more than you are willing to spend, but these products are top notch, and you don't want to run the risk of marring your paint with some cheap lubricant.
  7. parttimer
    parttimer Member
    99
    11
    Jan 7, 2014
    Ram Year:
    Engine:
    I have never used the mitt type product, I use the speedy surface prep fine grade towel: Speedy Surface Prep Towel, speedy prep towel, clay towel, sm arnold clay towel, clay bar towel
    I also have this for my DA unit: Nanoskin Autoscrub System Start Up Kit
    The speedy prep is faster than clay, not sure about the mitt, I know many people use it, I just don't want to use something I wash my car with to decontaminate the paint. As for clay, up until a few weeks ago there was a patent and all clay came from the same supplier.
  8. EWC88
    EWC88 Senior Member
    1,342
    205
    Apr 2, 2013
    Southern NJ
    Ram Year:
    2002
    Engine:
    4.7
    Not at all over budget, honestly I don't know what clay and stuff go for, I just know the good ole saying "you get what you pay for" so I am always willing to pay extra for a premium.
    I am very nervous doing it since it's my first time. Anyone have any pointers?
  9. Sparkyy
    Sparkyy Senior Member
    2,306
    529
    Jun 20, 2012
    Northern New Jersey
    Ram Year:
    Engine:
    Hopefully this linkage is ok, mods if not, please remove it.
    I am interesting in claying my truck and pretty much everything from start to finish but being in apartment complex pretty much makes this impossible.
    However, I've run across this website before and shows how to clay bar.
    Maybe other users here will give better/different tips?
  10. scottyram
    scottyram Senior Member
    256
    42
    Sep 18, 2012
    Ontario Canada
    Ram Year:
    Engine:
    Very good info on the link you provided. Claying is fairly straight forward, take your time, make sure you use lots of spray lubricant and try your hardest not to drop your clay on the ground.
Share This Page
