Yup...it's the Neutral button. It unlocks everything so you can flat tow the truck.
You can also coast really really fast down long grades using it but I don't recommend it.
Nice! Good job guys. Now... Why wouldn't you just turn the ******** dial to Neutral instead?
+19.05 mmfactory sport wheel offset for the 20" wheels. is it -19 or +19
If you are talking about transmission neutral, most transmission oil pumps are not driven by the prop shaft, the engine must be running. Oil won't get to the moving parts and things burn up. Now you could flat tow with the engine running If you are talking about why they just don't put transfer case neutral on the mode dial, the safety guys want to make it difficult to do.... see the post above about going real fast down hill I think the fact that transfer cases don't have synchros on the neutral disconnect makes shifting at speed undesirable from a wear point of view.
Tried it eh ???.............................
whats that fold out part that comes from under the rear seats to make a solid floor? whats it called so I could try to find it
Exhaust brake question (Cummins newbie).
It has two settings, one is apparently ON and the other is ?
What is the right way to use this? Do you leave it on one of the settings the entire time you're towing in mountains? Or is it only used in specific instances where you need extra engine braking? The manual has very little to say about using it.
