Rockynymia
- Feb 23, 2016
- 18
- 1
- 2004
- 5.7L Hemi
I have a 2004 dodge ram 1500 5.7L 4x4. I have replaced inner and outer tie rods. Upper control arm and ball joints and lower ball joints. Driver and passenger wheel hub. Two front calipers along with pads and rotors. Rear rotors and pads. All 4 shocks with rancho rs9000xl. All 4 tires with bf goodrich ko2 all terrain( mounted balanced and aligned) (5th time the vehicle was aligned this year in attempt to center steering wheel. All this was done was in an attempt to correct two issues I still have. Vibrations felt when driving 65 mph and up and a crooked steering wheel. My rack and pinion boots are both leaking and my power steering pump is squeaking. I am going to replace them but want to know if the rack is what's causing the off center steering wheel and could be the culprit behind the vibration. There is a little play in the wheel as well. Thanks
