Ram 2500 Diesel Winter Driving Tips
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
My 2014 block heater draws 6.3 amps, so thats running at 750Watts
Voodiloquist
Chesapeake, VA
Cummins
I have not yet found my '14 3500 block heater power cord. Would someone please direct me to its location?
Thanks.
Stangshcky12
Oshkosh, WI
5.9 Cummins
A lot of times they will have the heating element but no cord
The element is screwed into the block near the oil filter on the passenger side
The plug on your truck would be behind the bumper above the passenger side tow hook
It clipped up in
Voodiloquist
Chesapeake, VA
Cummins
Thanks for the info…just had a quick look see but could not find anything. I'll take another look tomorrow in better light. Pitch black and raining in Chesapeake.
Rotzilla
colorado
6.7 CTD
My manual said it would be on the left front near the tow hooks, when I finally found the cord it was on the right side up inside the bumper area. Keep looking it was a pita to find.
couleeman23
Magrath
13/14 Ram 1500's
Perfect thread. I was looking for this. Another question I have, mine came with a winter front from dodge. At what temperature range would you use it?? Don't want to over heat the truck for sure but any bit helps.
CDN Ram
Ottawa Ontario
2014 Laramie
6.7L CTD
I run my winter covr all winter long, it has flaps you can open and close depending on the external temperature. I wouldn't worry to much about over heating the engine it could be done but it would have to be well above freezing or towing a heavy load. I put mine on around October in Canada temps around 5'C or 45'F, and leave it on till spring when the temps go above that again. I only open and close flaps if the temp rises to high.
