Ram aux switch panel
John-Dennis
Houston
I have a 2016 Ram 1500 Big Horn and I want to add the aux buttons to my factory switch panel.
A
Can you tell me which part number I need and do you have one?
Is it necessary to replace the entire panel or can I remove the lower blanks and just add the switches.
I can not post photos so I will describe my panel: Trailer Brakes, Blank, Traction Control, Tow-Haul, blank, Park Rear, Park Front
I have seen several part numbers on this forum, but they do not seem to be the right one.
www.jdleech.com/Ram/Ram-Switches/Ram-Switches/n-F5rW4k/i-L3QnL2n/A
Thanks
John
6.4 L
You can’t just swap out the switches, you will need to swap out the whole panel but...it’s not just the panel it is also a module under the hood that accepts the added auxiliary items. Plus I’d assume you would need the dealer to flash your computer to accept the different module/switches. Don’t think I’ve ever seen it added to a 1500 before. If you feel like going through all that try Moparpartsonline and ask them for the part numbers. They are pretty good with finding that info.
J
John-Dennis
Houston
My intent is to hook the switches to a custom relay box to bypass the canbus completely.
Several people have posted about doing that but with slightly different switch modules.
AllMoparParts.com
- Benny
Preferred Vendor
All
All
A
Ram Switches - JohnLeechPhotography
Thanks
John
Hi John,
Can you please message me your VIN. I will need to check your current options and see if a switch panel exists with the combination your looking for.
Thanks,
Benny
RedFlameRam
