Hopefully somebody can help me here. I am have a noise that is coming from the pass rear door area on my '14 QC. It's more prevalent when cold out and makes a tap noise whenever I run over a minor bump in the road. With winter approaching, its driving me nuts every morning. Best explanation of how it sounds is a bolt or nut loose in the door or a heavy cable hitting the body, it sounds like a solid tap.
I've had my kid listen in back while I was driving and he seems to think its near the hinge side of the rear door or in the B pillar. In an effort to find it, I removed the B and C pillar trim to hunt for loose stuff, I pulled the drivers rear door panel off and the speaker too to feel around inside. I've looked under the truck and tried restraining the e-brake cables, brake and vacuum lines and I cant find this elusive demon.
Its not the rear seatbelt buckle hitting the c pillar. I do have Mopar side steps but the noise happened prior to the install.
Anybody have any suggestions?
