RDS Auxiliary Fuel tank/Tool box
Discussion in '6.7 Common Rail' started by Arctic-Rodz, Aug 15, 2015.
  1. Mallardsx2
    Mallardsx2 Member
    33
    Jun 5, 2012
    Ram Year:
    Engine:
    Cummins 6.7
    Is there a size a little wider do you don't have so much space between the bed sides and the box?
  2. Jackfate
    Jackfate Senior Member
    105
    11
    Feb 18, 2016
    Ram Year:
    2016 1500
    Engine:
    May I ask the total cost of this project?
  3. Arctic-Rodz
    Arctic-Rodz Senior Member
    845
    130
    Jul 1, 2013
    RGV, TX
    Ram Year:
    2014 2500
    Engine:
    6.7L Cummins
    you might find another one that will tuck up closer to the sides but I find those sides pretty handy. I keep a spare gallon of windshield washer fluid in there. On the driver's side is where the feed tube goes down to the filler neck so you do need that space.
    I paid about $1000 for everything. Including the installation and bedliner on the tank/tool box. Buddy works for at the installation place so they hooked me up pretty good!
  4. Arctic-Rodz
    845
    130
    Jul 1, 2013
    RGV, TX
    Ram Year:
    2014 2500
    Engine:
    6.7L Cummins
    It would take A LOT of vapor to fill that area. I typically open the tonneau cover several times per trip for luggage and stuff. I was concerned with my luggage smelling like diesel but I haven't experienced it on any of my trips. @ 100+ degree weather either. So its been good.
    I only have a valve with an electric butterfly which allows fuel to drip down to the main tank. It also has a secondary hand valve which closes the fuel supply if you need to service that electric valve.
    I haven't used my top tank to fill up my tractors. Since i use regular fuel to fill my truck. I just carry a couple of spare plastic 30gallon tubs when i need to haul fuel for my tractors (red dyed) and use a Northern Tools purchased transfer pump which powers itself from the tractor battery. Pretty handy.
    So my tank is only used to fill my truck.
  5. drittal
    drittal Senior Member
    1,541
    582
    Apr 24, 2015
    E. Montana
    Ram Year:
    Engine:
    6.7
    You could, but this tank is bigger than your fuel tank so you will either have to stop and wait for main to to be filled by gravity feed, or pull over again to shut it off before you overfill the tank. A friend of the family does it this way but has a 28g tank. He gets down to 1/4, stops and opens the valve and drives off.
    Run the vent line outside the bed
    Sent from my SM-N900V using Tapatalk
  6. drittal
    1,541
    582
    Apr 24, 2015
    E. Montana
    Ram Year:
    Engine:
    6.7
    [​IMG]
    My father in law's RDS tank. He mounted a 20gpm pump inside the tool box area with a hose and dispenser. He leaves the switch at the pump on and runs a relay with a toggle switch inside the cab to turn it on and off. 51 gallons.
    [​IMG]
    My father's set up. This one is plumbed into the filler neck with a small diesel fuel pump with an in line filter with a switch in the dash. 58 gallons.
  7. dewey405
    dewey405 Junior Member
    35
    Oct 25, 2016
    Ram Year:
    Engine:
    Pentastar V-6
    I know I am digging up an old thread but how does this one fit? The measurements on NT website show it being 1" too wide to fit between the wheel wells.
  8. Arctic-Rodz
    845
    130
    Jul 1, 2013
    RGV, TX
    Ram Year:
    2014 2500
    Engine:
    6.7L Cummins
    my tank fits perfectly. It doesn't touch the wheel wells, it sits right behind them.
Share This Page
