Rear differntial
ramoutdoorsman
IL
2012 Outdoorsman
I have a 2012 ram 2500 with the 5.7 hemi. My manual says rear diff is a limited slip but does not require an additive. Why is this?
JPT
NY
2015 Big Horn
I believe 2500’s have a gear driving Limited Slip, unlike us 1500 guys. The clutches need the friction modifier, gears dont.
Gear driving LS are way better (do not wear out, and will not slip under heavy load), be glad!
The Ram doesn't use a "real" limited slip. They use independent braking of the wheel that is slipping, rather than clutches in the rear diff.
Better do some more research,the limited slip in the 1500's is a clutch style posi/limited slip.You're thinking of traction control,which is differant from what a limited slip does.
Jeepwalker
WI
2012 Reg Cab, 4x4
Viscious coupling??
If so, those are great! Our Jeep has them front/center/rear.
Burla
2010 Hemi Reg Cab 4x4
If you use a premium oil you likely wont need additive. Read here, you only use if you have chatter. I can't remember how many guys have changed their dif fluid, so far none have needed the modifier. You do not want to add it if you don't need it, that can be bad.
ColdCase
Its a gear type diff in the 2500 of that era. No clutches no additives needed. There is a pretty good description around here somewhere. Lots of advantages but the biggest disadvantage is that it needs some traction to work. Lift one rear wheel off the ground and you go nowhere, nothing gets transferred to the other wheel.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
What style posi do the new 2017s have? My truck has the anti spin diff, but i don't know much about it. Thanks
spoon059
Just north of Washington DC
6.7 CTD
Oops, my apologies. The 2500's use braking, I thought the 1500's did as well.
Tach_tech
5.7L HEMI
They all use braking to improve traction when wheels are spinning. The 1500 has a clutch style limited slip while the 2500/3500 use a gear style limited slip. Both do the same thing just in slightly different ways. All ram trucks have a limited slip rear diff as an option.
Ram Night
Southwest, Michigan
If you have a 1500, you have the ZF rear end and the limited-slip differentials have clutch packs behind the side gears inside the diff.
Here is a photo I took of a open diff on the left, and a SL unit on the right when I replaced the open diff with a LS unit in my 16 Rebel.
