Rear spacer
Cmsharp
Rogers, AR
Recently had a poly 3/4 inch rear spacer installed on my 2016 ram 1500. Before installation the drivers side rear measured 39.25. Now it measures 39.5. Mechanic installed it on the bottom of the coil springs. Should it have been placed up top? The spacers didn’t come with instructions. Everything looks legit with the springs. I’m at a loss. Thanks for any insight.
JB1
Houston, Texas
Those are TGC poly spacers and yes they mount on the bottom. I just asked the seller about these Monday and he verified that. Many members here have those exact spacers installed on bottom. Hopefully they will reply about height increase
JB1
Houston, Texas
anyone else that has these spacers.....did you get actual .75" lift?
crazykid1994
I installed the 1” steel spacer that goes on top and only got 3/4” lift
Iggy4935
I have 1.5” spacer and it goes on the bottom.
Cmsharp
Cmsharp
Rogers, AR
Yeah I researched them and found different answers about top/bottom install. The mechanic, who i trust said he always installed these on the bottom of the spring. Everything looks great with the setup. Im starting to wonder 2 things: 1)Could the springs be so soft that they just compressed more instead of actually lifting? 2)Maybe I measured my truck with an empty tank of gas before?
JB1
Houston, Texas
I have a set of the same ones coming UPS, should have them on before Christmas so I’ll reply back after install.
LVnight1500
I got the 3/4" metal ones from TGC, and it says to install them on the top.
crazykid1994
Most have the Metal ones on top and the poly on the bottom.
JB1
Houston, Texas
I found a pic I had saved on my computer. This isn’t my truck but mine show delivered by UPS today.
Cmsharp
Cmsharp
Rogers, AR
Thank you. That’s exactly what mine look like. Truck rides the same, no squeeks. Going to measure later this week with 1/2 tank of gas to see if that was why the measurements are off.
JB1
Houston, Texas
I opened the box and mine measured 3/4” thick
808ram1500
Big Island, Hawaii
4.7L
Is there an eBay link to these 3/4" rear poly spacers? I can't seem to find it.
Would this work on a 6" RCX lift with Bils set at 2.1 in the front. The rear end of my truck looks a little lower than the front. Being the RCX rear spacer is on the top and polys go on the bottom, Is it doable?
JB1
Houston, Texas
Here is the ebay link, you can vuy it directly from them online but the shipping for me was approx. $25 so ebay was cheaper.
https://www.ebay.com/itm/3-4-09-15-...ash=item51fce55b22:g:-IwAAOSwrjBZ94-7&vxp=mtr
https://www.topguncustomz.com/i-254...rear-poly-coil-lift-spacers-leveling-kit.html
RamRoy
Crestview, Florida
Can you use the polys on bottom with a lift that has spacers on top? I need an extra inch in the rear
