Whiteannerdy
- May 30, 2017
- 119
- 53
- 2016
- 5.7L Hemi
Installing Bilsteins and rear spring spacers on Monday. Been searching around for all the torque specs but I’ve come up empty handed for the rear stuff.
Correct me if wrong on any I have already.
Front:
Upper ball joint Nut 21mm @ 70 ft/lbs
Tie rod nut 21mm @ 55 ft/lbs
Brake caliper Bolts 21mm @ 130 ft/lbs
Lower strut bolt 21mm @ 100 ft/lbs
Three upper strut nuts @ 40 ft/lbs
Upper sway bar link @ 27 ft/lbs
Rear:
Rear Trac Bar Bolt @
Upper Sway Bar End Link @
Lower Sway Bar End Link @
Upper Shock Bolt @ 100 ft/lbs
Lower Shock Bolt @ 100 ft/lbs
Edit:
Found the list of torque specs but unsure of which is the upper/lower Sway Bar link and what the Trac Bar Bolt is.
http://www.ramforumz.com/showthread.php?t=176760&highlight=Torque+spec
Front:
Rear:
Edit:
