Somehow the clear plastic cover of my gauge cluster (2015 Laramie Limited) has developed a large crack. Dealer says not covered as it is 'wear and tear".
As far as I can find out on line I need to remove bezel and cluster comes out with a simple plug in rear.
It seems that I cannot buy just the clear plastic but need to buy the whole unit at about $500 !!
I thought about finding one in a junkyard but when i plug in the used unit what about the odometer setting?
Looks funny if you go to dealer and vehicle has less miles than previous visit.
Any thoughts?
I considered removing the unit and finding a clear plexi sheet at Home Depot or off a used unit at junkyard but have been told I cannot remove the clear plastic as it is electronically "welded' to cluster.
I don't want to spend $500 but if i did again what about the milage reading of 0 miles on new unit.
Lastly, any computer issues if i unplug old and plug in new/ Will i need dealer to reflash or something like that/
Appreciate the help
Any thoughts?
Appreciate the help
