Replacing the Power Steering Pulley
Discussion in 'General Discussion' started by HAS0586, Feb 21, 2014.
  1. HAS0586
    HAS0586 Junior Member
    Feb 21, 2014
    Ram Year:
    2000
    Engine:
    v8 5.9
    Hey All!
    I started noticing a chirping sound coming from under the hood (2000 Ram v8 5.9) and after some investigation saw that the power steering pulley was a little loose. Should I replace the entire pump or can just the pulley be replaced? I can't tell just from looking at the photos of the parts online.
    I am a little frustrated because I just had the tensioner replaced about a month ago and the alternator and idler pulley replaced by a shop a few days before I started noticing the noise.
    Any help appreciated!
  2. Merc225hp
    Merc225hp Senior Member
    5,141
    3,118
    Jan 13, 2013
    NA
    Ram Year:
    truck
    Engine:
    gas
    You can get just the pulley, you need a spiecal tool to remove and install it. I would remove the pulley and make sure it's not the shaft going into the pump, and have a new PS pump on hand in case you need it.
  3. HAS0586
    Feb 21, 2014
    Ram Year:
    2000
    Engine:
    v8 5.9
    Good advice Merc225hp. I will be sure to get both the pulley and the pump just in case. Thanks!
Share This Page
