Replacing turn signal stalk/multifunction switch
Discussion in 'Interior' started by Boosted Motorsports, Dec 27, 2016.
  1. Boosted Motorsports
    Boosted Motorsports Senior Member
    238
    84
    Nov 2, 2011
    Ram Year:
    Engine:
    My turn signal switch/stalk is acting up when turning left. It doesn't always return to the middle and I have to sometime lift it up to help it out.
    I took the switch apart and tried greasing the mechanism but even with the stalk out of the truck and in my hand testing, it still sticks so im guessing the plastic just wore out a bit (92k miles).
    My truck is out of warranty and it is part #56046114ad which is now superseded by part# 56046114ae
    Do these new trucks require re-programming if I end up getting stuck with the superseded part? I know the german vehicles are very picky with stuff like this and I can't do anything on my VW without reprogramming modules.
    Also anyone know why it got superseded or if there was an improvement?
  2. MADDOG
    MADDOG CTD Driver Staff Member
    7,091
    1,872
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    Cummins 6.7L Turbo Diesel
    If the functions of the new part number are same as the old unit, no reflash is necessary.
    I have no idea what the changes were.
  3. raff18
    raff18 Member
    37
    77
    12
    Jan 12, 2015
    Sudbury canada
    Ram Year:
    Engine:
    changing is super easy
    from what i remember its only a 4 wire plus and i don't even think its screwed in
    it just pops in and out
    i did a 2012 caravan and was surprised at how easy it truly was
    can't see trucks being any different as they run off the same system
  4. Boosted Motorsports
    238
    84
    Nov 2, 2011
    Ram Year:
    Engine:
    Yeah I already had it out and took it apart to regrease it but still is sticking.
    Just the two screws that hold the column cover on, then release the latch, no screws and it pulls straight up.
  5. Birddog
    Birddog Senior Member
    2,466
    826
    Sep 1, 2012
    West Palm Beach, FL
    Ram Year:
    2016 Bright White 3500 Laramie 4X4 Long Bed
    Engine:
    6.7 Cummins TD, 3.73
    Seems like a lot of miles but easy to do if you live far from work. I put just over 54k in one year.
  6. raff18
    raff18 Member
    37
    77
    12
    Jan 12, 2015
    Sudbury canada
    Ram Year:
    Engine:
    from what i remember that the switch is released by a nub on the column. if you look at your switch the part that faces inwards. when you flip the switch the nub pops out. if you press on it that should cancel it to the off position. if its working like it should then id be looking at that column.
  7. Hootbro
    Hootbro Senior Member
    2,015
    969
    Jul 31, 2015
    Ram Year:
    2015 2500
    Engine:
    If the last two letters of a part number roll and the front part stays the same, that newer part most times is backwards compatible and is just a in line change for whatever reason that may have corrected a defect or other internal change.
  8. 00R/T
    00R/T Supporting Member
    1,448
    893
    Apr 18, 2016
    CT
    Ram Year:
    Engine:
    This. It means the part has been superseded, and the new version is considered the correct replacement for any vehicle that used a prior version.
Share This Page
