Reverse level questions
Discussion in 'Lowered' started by Mohpar, May 17, 2016.
  1. Mohpar
    Mohpar Senior Member
    212
    21
    Dec 30, 2015
    Ram Year:
    1999
    Engine:
    Magnum 5.9
    What is the largest tire size you can run with no front or rear spacers?
    To reverse level, do you simply unbolt the U-bolts holding the rear blocks in, take the blocks out, and tighten the U-bolts over the bare springs riding on the axle? Video or pictures?
  2. dapepper9
    dapepper9 Senior Member
    22
    4,777
    1,855
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    Reverse level you are correct is removing the rear block. HOWEVER, do not reuse the ubolts. They're tty and you'll need a new set of factory 2wd u bolts. Should still be able to run 33s fine, maybe a little bit of rub
Share This Page
