Riddle Me This...Trans Question
Silver Tex
Reman. trans came with a few seals (o-rings). These are intended to be used in the swap of transferable components between old and new.
I have moved neutral start/backup switch (o-ring), speed sensor (o-ring) and dipstick (tube seal) & cooler line connections over. I cannot figure out where or if this o-ring (picture) is needed. The multi-pin connection that (I'm guessing) communicates with the PCM comes pre-installed.
Any thoughts?
Thanks,
Scott.
