BlkRamRt
Are you happy with the sound now?
For the most part but I still have to add some sound deadening to my doors to get the most out of my midbass drivers.
So, I have everything working now. I probably have 3 full days into it. Allot of that was troubleshooting the DSR1. The DSR1 is pretty sweet. I have it feeding a Punch 1000X5. Installed Alpine R Type front and rear with the tweeters in the stock dash corner locations. I was worried the tweeters would be too bright but they are perfect. I did set them to the -2db setting on the crossovers. I also installed the JL stealthbox. It turned out even better than I had hoped.
I did end up having to install 500 ohm resistors on the input side of the DSR1 so the stock system would see a load. It wouldn't work without them. Bypassing the factory Alpine amp makes a world of difference.
Drivers side right above the parking brake. If you have the 6 speaker system then you don't have an amp. Only the Alpine system has it. You can still use the DSR1 though. You will just use the high level inputs on the DSR1.
Good luck!
Sirius is bad even on the OEM setup. Its the compression they use for alot of the channels.Has anyone else that's installed the DSR1 noticed how terrible the other functions sound? The audio on a phone call sounds absolutely terrible! Even sirius radio sounds worse. Music off the iPhone sounds incredibly clean, but other sources are bad. Any ideas?
