Rough Idle 2006 1500 4.7 Big Horn
Discussion in 'Engine & Performance' started by 2006 Dodge Ram 1500 4.7, Sep 25, 2012.
Sponsored By: Moe's Performance
  1. 2006 Dodge Ram 1500 4.7
    2006 Dodge Ram 1500 4.7 Junior Member
    Sep 25, 2012
    Ram Year:
    2006
    Engine:
    4.7
    I noticed recently that when I start the engine it will rev several times then it will settle down, and then it can be rough when at stop lights, also can seem a little sluggish going up hills. So I had new plugs put in, fuel system cleaned, changed the air filter, oil change and for good measure changed out the transmission fluid and rear diff. fluid.
    But the issue still remains, not sure what it is, any ideas?
  2. quietpeen
    quietpeen Administrator Staff Member
    22,568
    2,100
    Jul 14, 2010
    Ram Year:
    2016 1500 Sport Crew Cab 4x4
    Engine:
    Welcome to RF. members with ideas will chime in soon
  3. bigbadram1500
    bigbadram1500 Administrator Staff Member
    39
    15,302
    598
    Jul 7, 2010
    Springfield, IL
    Ram Year:
    2008
    Engine:
    Welcome.
    hmm not sure, has it thrown any codes? Rough idle and sluggishness could be the egr possibly.
  4. RamSLT
    RamSLT Member
    85
    Jun 19, 2012
    North part of KCMO
    Ram Year:
    2010
    Engine:
    4.7L
    What's the rpm range at stop light?
    When you say it revs, what's the lowest it revs and the highest rev?
    Reason why I ask is I've had a bunch of a vehicles do that and it's always been the EGR or the throttle positioning sensor has gone bad.
  5. drkmtr
    drkmtr Member
    80
    May 1, 2012
    Copperas Cove, TX
    Ram Year:
    Engine:
    4.7
    From all my research with a similar problem, it is usually the Idle Air Controller or the Throttle Position Sensor or both. There is a great video on YouTube for testing the TPS. If it is bad, there ya go; if not look at the IAC, they are really cheap on RockAuto. I had to clean my IAC up, the dang crankcase vent is so close in the airbox to the IAC that it can get gummed up and stop working correctly. Not all of the 4.7's have an EGR valve, so make sure your year and version has one before going down that road. I wasted some serious time trying to get a new EGR valve for mine only to discover that it didn't even have one nor does it have fuel "filter" either. Good luck in getting it fixed, and shop around for your prices on the TPS and IAC, some places are rip offs for them.
Share This Page
