Rough idle, shaking on acceleration.
Discussion in '3rd Gen DIY' started by nyfz1man, Dec 11, 2016.
  1. nyfz1man
    nyfz1man Junior Member
    22
    Dec 11, 2016
    Ram Year:
    2002
    Engine:
    5.9 360
    So recently purchased my 02 Dodge Ram 1500 quad cab and have been experiencing some troubles.. 5.9 motor has 133k on it.
    When I go out for a drive it shakes aggressively on acceleration around 1,500 RPMS and typically in over drive. Some have been leading me towards drive shaft but this problem only occurs when accelerating. If I take my foot off the pedal it stops immediately. I have changed spark plugs, spark plug wires, distributor cap,Throttle position sensor, o2 Sensor, Fuel injector cleaner, ran marvels mystery oil thinking it was a sticking valve. Running out of options and looking for some advice. Along with the shaking on acceleration, I am also getting a rough idle from time to time.
    The codes that i have received are..
    P0138- 02 Sensor Circuit High Voltage
    P0307- Cylinder 7 Misfire Detected
    P0172- Fuel System Too Rich (Bank 1)
    P0132- 02 Sensor Bank 1 Sensor 1
    Sent from my SM-G920V using Tapatalk
  2. destroyaYO
    destroyaYO Member
    30
    54
    25
    Nov 22, 2016
    Ram Year:
    Engine:
    5.7L V8 Hemi
    I would check/ all O2 sensors and possibly replace cats if you have emission regulations
  3. nyfz1man
    22
    Dec 11, 2016
    Ram Year:
    2002
    Engine:
    5.9 360
    Is it possible to check my o2 sensors with a scan tool prior to replacing them? Having a hard time dropping hundreds on parts that may be perfectly functional.
  4. pajeepman
    pajeepman Senior Member
    128
    Aug 30, 2015
    SE PA
    Ram Year:
    2003
    Engine:
    5.9 magnum
    Any idea on what part # you used for front O2 sensor. The one listed for my '03 5.9 1500 has a wire that is wayyyy too short.
    Sent from my SM-J320P using Tapatalk
  5. nyfz1man
    22
    Dec 11, 2016
    Ram Year:
    2002
    Engine:
    5.9 360
    NTK Oxygen Sensor
    Part No 23132. Picked it at Advanced Auto and perfect fitment. Heard some rumors that Bosch o2 didn't work well with the Rams so I stayed safe and went with the NTK.
Share This Page
