Round Air Filter
bluwarguy
5.9 Magnum V8
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
They sell kits to add small round filters to the pcv hose.
as for anything else, you just have to make sure it doesnt fall off the TB :roflsquared:
dapepper9
Iowa/Nebraska Border
5.9L V8
Nope. The edelbrock 10x2 round element from any parts store works pretty plug and play with a spectre s bolt (also found at these parts stores). 14x3 however is the only way to get one with a cotton filter instead of paper and requires a drop base. Spectre bolt works fine still, k&n kit cam be found at autozone that's pretty plug and play with the bolt. Many have a spot for the pcv hose as well
Gr8bawana
6.7 CTD
Why would you want your truck breathing in hot air from under the hood? There is a good reason these trucks have a snorkle to bring cooler air in from outside the underhood area.
dapepper9
5.9L V8
You don't really believe that crap do you? You won't notice any difference between the 2 especially with the iat heat soaking in the manifold
dudeman2009
Magnum 360
It won't really make a noticeable difference drawing from either. Unless you block the whole radiator with cardboard like I did.
With the cardboard in place, my coolant stays at a nice 200-210. the IAT was reading 65*F the other day fully warmed up after a 20 mile drive, and sitting in a parking lot running for about 5 minutes. I'm sure it would be a bit higher without the snorkel, maybe by 20-30*F. But it was ****** 12*F outside.
Perhaps you could notice a difference if you moved the IAT sensor. My truck was definitely more peppy even with the winter blend fuel than it is in the summer when the IAT sensor reads 150*F+.
