S&w ar15-22
Discussion in 'The Great Outdoors' started by Lil_Ram, Nov 28, 2016.
  1. Lil_Ram
    Lil_Ram Senior Member
    1,172
    555
    Apr 10, 2015
    Ram Year:
    2003
    Engine:
    Power tech 3.7L
    Curious if anyone here might have this AR. Considering it as one both the misses and myself can shoot just for fun. She's not used to the larger calibers yet so something small first and get a larger one later.
    I already know the .556 will be to much for here since I've shot M14A2s in the past and the pistol is a S&W SD40 and she can't shoot it.
    Wondering if anyone can shed some light
    Rustycowl69 likes this.
  2. sriley531
    sriley531 Senior Member
    458
    324
    Feb 4, 2016
    Ohio
    Ram Year:
    Engine:
  3. Lil_Ram
    1,172
    555
    Apr 10, 2015
    Ram Year:
    2003
    Engine:
    Power tech 3.7L
    Wow okay definitely great bit of knowledge. I knew S&W firearms work better with specific types of ammo. My SD40 in particular is one that's finicky with cheaper ammo. But this is a different story.
    On a side not got any insight on the mossberg version it wasn't second choice here
  4. Kytow
    Kytow Senior Member
    29
    429
    142
    Apr 27, 2016
    Ram Year:
    Engine:
    Friend had one. As stated above it had cycling issues a lot. Haven't heard about the mossbergs
  5. Lil_Ram
    1,172
    555
    Apr 10, 2015
    Ram Year:
    2003
    Engine:
    Power tech 3.7L
    Very strange. I googled reviews and stuff on it and couldn't find anywhere of people saying that. All only good reviews but nothing was newer than August. Where as that article was September. Wonder if maybe a bad batch of guns were released
  6. kg93
    kg93 Senior Member
    24
    1,596
    456
    Nov 7, 2014
    AZ
    Ram Year:
    Engine:
    I have one personally. I have a magpul carbine stock and grip on it with a red dot site. Its a fun little toy pretty accurate. I am garbage at cleaning my guns since when i get home from the range im too lazy.
    That being said, ive shots over 1000 rounds through it and havent had one cycling issue. All federal ammo
    no recoil at all and sounds like a bb gun
  7. Lil_Ram
    1,172
    555
    Apr 10, 2015
    Ram Year:
    2003
    Engine:
    Power tech 3.7L
    Good to hear I've been doing research into it and there seems to be a common thing correct ammo and cleaning. Also saw a video about bending the I believe it was the fin on the guide pin for the extractor problem
  8. MADDOG
    MADDOG Super Moderator Staff Member
    7,625
    2,075
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    Cummins 6.7L Turbo Diesel
    I own one and it seemed to be a bit picky at first with extracting the cheaper ammo. The Remington Golden Bullet, Winchester Wildcat & Aquila had a lot of FTE problems.
    I switched over to Federal Champion bulk 325 pk, CCI MiniMag & Winchester SuperX and haven't had a problem since.
    I also ran across a simple extractor tweak you can do to reduce FTE problems.
    https://www.youtube.com/watch?v=wO76HC9tD4g
    I like the M&P 15-22 a lot.
    [​IMG]
  9. Lil_Ram
    1,172
    555
    Apr 10, 2015
    Ram Year:
    2003
    Engine:
    Power tech 3.7L
    Yeah that's the video I saw or one similar to it and I run federal through my SD40 already cause it doesn't FTF as much as the Winchesters did
  10. RubberFrog
    RubberFrog Senior Member
    108
    5,695
    283
    Jun 26, 2010
    Ram Year:
    Engine:
    Cummins
    Why not just stick with the time proven reliable 10/22 platform?
Share This Page
