"Sales code" for front/rear LED signals
firebuff17
Ct
Looking for some help.
I have a 2014 1500 CC
I have installed aftermarket LED bulbs for my front and rear incandescent turn signals and brakes. I knew I would have to install resistors to stop bulb out and hyper flash.
I am figuring if I was able to get a dealer to flash my BCM with the LED sales code, I wouldn't need the resistors.
Anybody done this?
Anybody know the codes for the front and rear?
Thanks for your help
F
firebuff17
Ct
Nope. Never figured them out. I ended up just adding resistors
Jeep946
Cummins 6.7
What is the last 8 of your vin and I can get that info
F
firebuff17
Ct
Thank you for the offer. But I have since changed my fronts out to OEM projectors and I am using the conversion harness from JJ at Retroshop. In the rear I tapped off of the trailer harness using a T-connector from Curt to avoid cutting any factory wiring.
As that’s what I was trying to avoid, cutting factory wiring, I accomplished my goal.
Thank you
Joseph Rangel
Alaska
With alfaobd you could had change the setting in your BCM, I just installed LED Hi and Low and the program works just fine.
