edgaram
i have a 2006 ram laramie 5.7 hemi 4x4
i seized my engine and im going to rebuild the engine. something broke inside like a piston i know that because i found big broken metal pieces inside the oil pan. the engine is ready to be taken out ive disconnected everything im just missing the four bolts that are on the flywheel and thats my problem. because the engine is seized it wont turn and my fly wheel wont turn either. i can only get to one bolt at a time and to get to the others it has to turn.
has anyone faced this problem? can anyone give me some advice. do i force the flywheel to turn by applying alot of pressure? or will that cause a bigger problem? is there another way to take off the 3 bolts i cant get to?
thanks
thanks
