Shifter loose
Discussion in 'Towing & Hauling' started by Kendall88, Jul 8, 2016.
  1. Kendall88
    Kendall88 Junior Member
    31
    10
    Jul 8, 2016
    Ram Year:
    2000
    Engine:
    V8 magnum
    Hi I recently got a 2000 Dodge Ram 1500 that is a 5 speed and shifter is loose while it is gear. I was wondering if anyone can show exactly where the the bolts are to tighten it. I was also wondering if this is an easy fix that won't cost an arm and a leg to fix at a mechanic.
  2. mitchbowers
    mitchbowers Senior Member
    910
    348
    Aug 3, 2014
    Ohio
    Ram Year:
    1996 2500 5-speed, soon to be leveled on 33's
    Engine:
    5.9 Magnum
    what probably caused it is leaving your hand on it while it's in gear, putting pressure on it&wears it out. I know it's a hard habit to break for me personally, but will only save the tranny in the long run. as to what would fix it, I have no idea. as long as it's not popping out of gear, it shouldn't be a problem
    Sent from my XT1575 using Tapatalk
  3. dudeman2009
    dudeman2009 Senior Member
    22
    1,395
    157
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    The manual lever is directly connected to the ball detent system. If you still have a clear detent in or around each gear the problem is not with that. But if it slides freely from gear to gear, then your detent arm is bent and let the ball fly out, that is a dealer part and requires the valve body to be dropped.
    If you still have the dent, the easiest places to look is right under the pedals on the underside of the cab. Just look for the metal rod coming of the driver side of the engine. You will have a cotter pin very soon off the shift lever. From there I believe there is a set screw that is for adjusting where the indicator sits in the dash, that has been known to come loose if it wasn't properly installed.
  4. dapepper9
    dapepper9 Senior Member
    22
    4,777
    1,855
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    He's got a 5 speed stick not the auto. There is no manual lever/detent system. His shifter goes directly into the top of his trans.
    As to what the fix is I'm not sure. You'd have to pull the carpet back and inspect your linkages. Probably wear as mentioned earlier. There's probably a way to tighten it up but i wouldn't know without looking at one
Share This Page
