i took this from the post listed.. credit to Olli as he got this answer from the RAM chassis engineer...
"The 5-link coil system does an incredible job of locating the axle and improving the ride. We put the Bilstein dampener in place for additional control, bringing us far beyond what competitors offer. The dampener exists on gasoline engine models (6.4 and 5.7 HEMI) but not on Cummins-powered trucks. Diesel engines have a much different torque curve and RPM range and do not currently require the component.
The five-link coil design incorporates support at all major points of force. Leaf spring suspensions struggle to combat axle wrap by using staggered shock absorbers (one mounted on the front of the axle tube and one mounted on the rear of the axle tube). The superior design of the five-link coil system functionally resists unwanted axle rotation. Leaf spring configurations also lack lateral support, forcing the leaf ends and shackles to hold against lateral loads — a task they're not particularly good at and one reason competitive leaf-sprung rear suspensions shutter on rough surfaces.
Because of the unique five-link axle control and natural rotation, U-joints in the driveshaft run smoothly and with less vibration through the suspension’s range of motion, an advantage not shared with leaf springs. Another benefit of coil springs is less unsprung mass and elimination of stick-slip friction found between the leaf springs. Additionally, links are engineered in-line with frame rails, so overall packaging is better, not to mention an overall weight reduction of about 40 pounds when compared to a leaf-spring configuration.
The 2014 Ram 2500 also will offer a segment-exclusive rear air suspension system. Two air bags replace the coil springs much like the Ram 1500. Load capacity is not sacrificed and the 2014 Ram 2500’s best-in-class ride and handling gets even better, crushing the competition with two doses of engineering innovation (five-link coil standard and air suspension option). Another benefit to the new air suspension design is the load-leveling capability, which automatically detects load on the rear suspension from a trailer or payload. The air pressure increases until the vehicle reaches normal ride height – leveling the truck and improving stability and loaded ride."
