ThanksLooks like just a step. It mounts to the rocker panels not the frame.
They are stout, I'm 235lbs, don't flex at all. They attach to the inside body holes from the factory,not the frame. maybe could take light scraping, but I would feel better if mounted to the frame.Is it heavy duty? Will it serve as rock guards or just as a step. Thanks
White Knuckle, unless you don't take your PW off-road, which then what is the point...
I'm in phoenix... i may have to get these at some pointProtection does have a cost. BTBH I have not noticed the weight. I'm down in the Southwest, and here in AZ and UT, rocker coverage is important.
