Single Exhaust Vs Dual Exhaust
Discussion in 'Engine & Performance' started by QuinnRam1500, Nov 6, 2014.
Sponsored By: Moe's Performance
  1. QuinnRam1500
    QuinnRam1500 Junior Member
    22
    Aug 5, 2014
    Long Island, NY
    Ram Year:
    Engine:
    Hey everyone,
    I've been looking into this subject for a little while now and I was wondering everyone else's opinion. I currently have a Dual Exhast on my 2007 Ram 1500. Although it is not a true dual exhaust as it looking like the owner before me wielded a new pipe onto the exhausting system. I was thinking about switching to a single exhaust system. I've had a bunch of friends tell me that a single exhaust is the way to go. That it helps give off more power and a loud sound.
    I'm really looking for opinions on the subject to help me decide what I would like to do.
    Thanks everyone
  2. Harley Harrold
    Harley Harrold Senior Member
    2,890
    325
    Mar 25, 2014
    Mississippi/Texas
    Ram Year:
    Engine:
    5.7L HEMI
    With the HEMI engine a single exhaust works best. You can achieve the duel exhaust look out the back, with a single inlet/duel outlet muffler. The true duel system doesn't provide enough back pressure which causes a loss in low end torque. This will make the truck sluggish on takeoff. If you go with Headers, you add a Y pipe which connects to the muffler and from there you can run a single 3" pipe out the back, or run two 2 1/2" pipes out the back. Remember, if your trucks emissions are visually inspected, you will need cats installed in the Y pipe. My system uses a single inlet/duel outlet muffler, with duel pipes exiting on the right (passengers) side, in front of the rear tire. I have read that not running cats in the system causes a foul smell, noticed especially, when running at idle.
    QuinnRam1500 and Tolson93 like this.
  3. Tolson93
    Tolson93 Senior Member
    24
    379
    21
    Jul 30, 2013
    Northern MN
    Ram Year:
    2003
    Engine:
    Harley Harrold,
    So a true dual setup wouldn't be the greatest? I like the sound of a true dual setup with two glasspacks but if it messes with back pressure then maybe it's not the route to go. Very informative reply .. Have you tested out the true duals?
  4. Tolson93
    24
    379
    21
    Jul 30, 2013
    Northern MN
    Ram Year:
    2003
    Engine:
    Currently I run a 18" glasspack 3in and 3 out swapped for the stock muffler.. I like it for a single pipe and have gotten lots of compliments. Seems like I have a little better acceleration when I put the throttle down about 3/4.. Was only 100$ for me too.
  5. 89gtcs
    89gtcs Member
    84
    15
    Feb 17, 2014
    Ram Year:
    2006
    Engine:
    Duals can work just fine, the problem is most people get pipes that are too large. For duals on a stock motor you should stick to 2" or 2 1/4" diameter.
  6. QuinnRam1500
    22
    Aug 5, 2014
    Long Island, NY
    Ram Year:
    Engine:
    Thanks Harley, A friend of mine has the same setup as you do. Although I'm not sure what muffler he has. As for myself I've been looking into doing the single inlet/duel outlet setup with duel pipes coming out the passengers side, two 2 1/2" pipes. Do you have any recommendations for Mufflers. I was thinking about a Flowmaster 44 series. I know there are other options just not sure what I want.
  7. 89gtcs
    89gtcs Member
    84
    15
    Feb 17, 2014
    Ram Year:
    2006
    Engine:
    Magnaflow is quite popular, and a few people use the Gibson mufflers. Check out Youtube and pick out what you like best.
  8. Harley Harrold
    2,890
    325
    Mar 25, 2014
    Mississippi/Texas
    Ram Year:
    Engine:
    5.7L HEMI
    I will be replacing my current exhaust system with all stainless steel parts from headers to tail pipe tips. The system I am looking at will run me close to $2,000.00 complete. The Headers are American Racing with 1 3/4" primaries, and 3" collectors, Y pipe, with cats, and Gibson muffler, dual tail pipes, and tips. This system will also exit on the right side in front of the rear tire.
    RonJon '06 likes this.
  9. chefred112
    chefred112 Senior Member
    527
    103
    Oct 13, 2010
    Tracy, CA
    Ram Year:
    2005 QC 2wd
    Engine:
    392 Hemi
    or do the best of both worlds...run duals all the way to muffler and then single out...o, you say you want it loud? throw dual cutouts on there as well :)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Hemi450hp likes this.
  10. QuinnRam1500
    22
    Aug 5, 2014
    Long Island, NY
    Ram Year:
    Engine:
    I want it loud but i doubt ill be able to go with that step up. I would probably get pulled over so quick lol.
    Looking at my muffler 10 min ago I notice I have installed already single inlet/ dual outlet muffler, with two pipes going to different ways to the back. Im wondering if I could just change the piping and have it come out the passenger side before the tire.
    Now my other question if I do new pipes I would have to do new tips right?
    Im also not sure which muffler this is. Like ive said before the truck is loud. Just wondering if changing it would be needed.
    [​IMG]
Share This Page
