I need some help trying to figure out what is going on with my truck
a little history, it's a 98 4X4 with 5.9 and 200+K miles on it
it started about 2 years ago, just every so often it would begin sputtering and skipping if left at idle for a couple min. then it would die
then my cat converter came apart,I was getting codes for every cylinder misfiring at different times. I replaced the cat and the upstream 02 sensor
also replaced the exhaust due to being all rusted out, the truck had dual exhaust on it but every parts store I called said it came with single, so I converted it down to 2 into 1
now before all that the truck had got to where almost every time it would sit and idle it would go into the spit sputter then die issue, if I was quick I could hold the throttle and bring the idle up and most of the time it would be ok
but other times it would spit and backfire like crazy when taking off
I would have to work on and off the throttle and finally it would clear out enough to go, then run like a top until the next time. sometimes it will run all day and never do it. after replacing everything it seemed OK for a few days then slowly went back to doing it again.
I replaced the cam pickup in dist, tune up is fresh
now it's coding both 02 sensors, off and on. I can clear the code and it may run a few days before it sets the code again, the skipping doesn't really jive with the codes because the light can be on and it run like a top and never miss a beat, or the light will go out on it's own but the truck run like crap at idle again.
